| Home · FAQ · New Posts · Private Messages · Search · Members · Members Map · Calendar · Profile · Donate · Register · Log In |
![]() | Home > Technical > Bonnet opens whilst driving :shock: |
| Endjin Joined: 22 Jun 2007 Location: Aberdeenshire Posts: 497
On the way to work this morning my F |
| Bobby Joined: 07 Jun 2005 Location: Kuala Lumpur Posts: 1888
This was a reported problem with the earlier models.
| shmoogle Site Moderator Joined: 07 Sep 2005 Location: My arse, Your face. Posts: 20308
Alas, as Bobby rightly says, this has happened a few times. I'm not sure there was ever any fix other than to say that it is/was quite easy to mislocate the bonnet catches when closing the bonnet leaving it liable to coming back up once moving. Although it sounds like teaching you to suck eggs, the general advice was to ensure that the bonnet closed evenly by ensuring you closed it with both hands, each one towards either side and actually pushed it into place rather than letting it drop.
| Markos Joined: 09 Dec 2007 Location: Ljubljana Posts: 50
You are not the only one with that problem. It also happened to me 2 weeks ago on RRS 2008 when I was driving approx. 120km/h on the highway and I could see the bonnet/spring lifting up slightly on the drivers side |
| TB Joined: 19 Feb 2006 Location: Depends who wants to know . . . Posts: 4918
This is a little disturbing. |
Interesting re the bonnet sensor - didn't know there was one of those |
The sensor is actually the bonnet alarm sensor. So if the bonnet isn't closed properly the alarm will sound when ever you try locking the car with the key fob.
Thnx for the replies chaps - Just as a point of note, there was defo no bonnet open warning and the last time I had opened it myself was over a week ago and I am always careful to make sure it is closed properly. When it popped it was audible inside the car, " a metallic POP", as if a latch had slipped or been forced. When I ispected the latches I expected to find one had sheared or come loose in some way - but everything looks fine and the bonnet is closed and appears secure (as it was before). Car is due for 1st service in 2k so I'll get the dealer to check it out then. Unless it pops again ofcourse! then I'll be straight on to them. Range Rover Sport - 2.7 TDV6 HSE - Java Black - Privacy Glass - Dealer Superchipped - a set of swanky TASMOD sill plates & Body Colour Matched SC Grill & Side Vents. |
If the bonnet is popping without warning it may be worth dropping into your stealers before the service. You never know when it may happen again. Arctic Frost TDV6 SE. Aspen Leather, Cherry Wood, Privacy Glass, PTI, Tow Pack, Mudflaps, Tasmods, a new Fuelflap, a RRSport.co.uk umbrella in the boot & a RRSport.co.uk sticker on the rear glass.
Too right - that could be downright dangerous... |
| Steve in germany Joined: 15 Nov 2007 Location: Bad Lippspringe Germany Posts: 717
Not the sort of thing to take a chance on. |
| Short Final Joined: 14 Jan 2008 Location: Kent Posts: 12
............ multiple catches cause dealers problems. Two times coming back from a service my FFRR was only half latched.
| sportman Joined: 25 Jul 2005 Location: UAE Posts: 517
