| Home · FAQ · New Posts · Private Messages · Search · Members · Members Map · Calendar · Profile · Donate · Register · Log In |
![]() | Home > Technical > New Member-RR Sport Aerial and Aftermarket Headunit |
| TB Joined: 19 Feb 2006 Location: Depends who wants to know . . . Posts: 4857
Hi Sandy - Welcome to the site.
| Sandy Joined: 06 Jan 2008 Location: Berkshire Posts: 8
Thank you TB for your very quick reponse.
Try contacting Prestige Audio they are one of the site sponsors. I'm sure they will help if possible.
| Bobby Joined: 07 Jun 2005 Location: Kuala Lumpur Posts: 1826
Could this be what you're looking for?
Thanks again guys for all your support.
| shmoogle Site Moderator Joined: 07 Sep 2005 Location: My arse, Your face. Posts: 20035
Of course, Sandy... that's what it's all about. Good luck |
| bermyandy Joined: 09 Sep 2007 Location: London Posts: 187
Would strongly recomend Prestige, for what its worth
Thanks again for recommending Prestige.
Okay Sandy.
| stephenw Joined: 12 Nov 2006 Location: Canberra ACT Posts: 68
Sandy, have a look at this. You will find other issues such as control of the message centre (resetting fuel consumption, changing the clock etc) when you replace the Headunit. It can be done but takes time.
Thanks again.
Sandy, the existing antenna is used for AM/FM. The TV antennas (one on-glass and the one on the roof) feed directly into the TV tuner box which is mounted in place of the HK amp under the drivers seat.
Thanks again for all you help Bobby and Stephen.
Glad it all worked out well. |
