Home > Maintenance & Modifications > [FAQ] DIY Trailer Light Hookup
Reply to topic  Down to end
AlanM
Canada 2007 Range Rover Sport Supercharged Zambezi Silver
I got frustrated with trailer lights today: I added a socket and wires directly to the rear light cluster, but upon using an indicator the system craps out and I get no indicator light at all either on the trailer or the car.
Any other cheapskate out there tried the same thing?
Any ideas anyone?
I should add that I have a little box in there to convert the English system on the car of separate indicator and brake light to the American system on the trailer of one bulb for indicator and brake light. This box worked fine on my previous RR2.
_________________
Come for a visit, Victoria is beautiful!
Post #88139 Wed Feb 28 2007 1:00am
AlanM
Trailer hookup for $3.00 not $300 !
Spurred into action by the idiot above, I got to looking at the problem more intensively. The twit just mentioned hooked up his trailer lights by splicing into the wires just behind the rear lights. Tut, tut this will not do it. LR have already wired up a nice pair of sockets for trailer wires and all you have to do is find these two sockets, determine which terminals operate which rear lights and plug into them.
Before starting remove the plastic bumper plate from just above the hitch (two wide flat screws), and ensure your vehicle does not already have any trailer sokets showing behind it!
Get a wide flat prybar about 18" long like this: (I kid you not.)
Prise off the lower left bit of carpet beside the tool tray lid. Prise off the rear of the left hand luggage compartment side panel. Move to the left rear door and prise up the rear portion of the left rear doorsill. (You might want to pull off the rubber door seal for a few feet.) Prise off the front of the side panel (the low forward bit is a sod). Remove the 12v plug then the panel can be taken out of the car.
The pre-wired sockets can now be seen attached to a metal bracket just in front of the rear lights. They are the ones with wires running into them but no wires running out of them. Detatch them from the bracket. Press on the release tab and pull off the dummy plugs on the ends (I can't see how to use these unless you have some terminals that will push into them - I didn't bother and discarded them).
LR have already catered for the conversion from English to American indicator/brake lights - just find the right terminals!
Solder a pin to the end of a spare bulb and a wire to the side. Ground the wire on one of the visible ground terminals. Switching on various lights on the car, use the bulb to test which socket holes on both sockets you need for your particular hookup (side lights, indicators, brake lights etc. There is even one that's always live).
Push a bit of coat hanger wire through one of the rubber grommets leading downwards and starting near the hitch thread the wire from your trailer plug the best way you can to avoid the 'big dangly weights' and reach the coat hanger wire, then use it to pull the trailer wire through.
Solder suitable terminals to each trailer wire and push into the socket holes you located above. Tape everything up to insulate it and stop it rattling.
Put everything back!
The dealer wanted $300 plus for the harness plus 1.5 hours labour. (In conversation with him I gleaned where the pre-wired sockets are and that there is no re-programming needed.)
My total cost $3.00 for a small four pin trailer plug.
_________________
Post #88145 Wed Feb 28 2007 5:39am
Alan - respect is definetely due Bow down Bow down Bow down
Post #88177 Wed Feb 28 2007 11:27am
Alan, you're a marvel with these things. Excellent stuff!! Thumbs Up
Stickied it.
_________________
Post #88257 Wed Feb 28 2007 3:43pm
Location: Growing old is mandatory; growing up is optional.
Good stuff mate Thumbs Up
_________________
RRS TDV6 Gone but still around
BMW 320D M Sport
And A Van For The Dog
Oh and i love the girlzzzzzzzzzz!!!
Post #88291 Wed Feb 28 2007 4:32pm
AlanM
Hey - I got another sticky !
Thanks guys.
(What to tackle next?)
_________________
Post #88450 Thu Mar 01 2007 5:54am
mlines
2007 Range Rover Sport TDV6 HSE Java Black
Has anyone had problems with "flashing" indicators?
Let me explain.....
I have a properly wired up towbar (factory fit) that works really well with trailers and caravans. However I now have replaced the old rusted out light units on my trailer with proper LED units. When I mean proper I mean E certified LED cluster units, not e-bay specials.
All the lights work fine on demand, sidelights, brake lights and indicators. However, both indicators continually pulse dimly when connected to the vehicle. The "Trailer" light does not come on when the trailer is connected.
I suspect that the pulsing is some sort of electronic sensing pusle to see if the trailer is connected and instead of detecting the low wattage LED units it simply flashes them.
Does this sound likely?
Martin
_________________
Real Off-roader - Suzuki Jimny (SN413), KAP 3" Lift, KAP Full Roll Cage, ARB Locker, On-board Air, Winch bumpers front and rear, Wrangler MT's, Recaros.
Post #150169 Tue Jan 01 2008 8:50pm
Tim in Scotland
Yes there is a problem with LED lamps and the LR wiring system - there is a cure for it over on the D3 forums IIRC.
_________________
A Carbon Footprint is the mark a lump of coal makes when it's dropped on the ground.
TDv8 HSE - Stornoway Grey with ebony and straight grain walnut wood-a-like interior with towpack, Tasmods. The best car I have ever owned
Now departed - Giverny Green TDv6SE with Aspen and Parchment interior - nearly the best car I have ever owned
Staying - Epsom Green Defender 90 for playing off road
Post #150175 Tue Jan 01 2008 9:43pm
xLusi0n
I just saw this thread after I installed my OEM wiring Very Happy HAHA, sucks. But, it was only 150 USD for me. And I guess I don't mind that for a clean install.
Lost 2 of those stupid clips. I never liked those clips.
Post #171751 Fri Jun 06 2008 12:53am
Reply to topic  Back to top
Site Copyright © 2005-2008 Martin Lewis
