Home > Technical > Filled up my TDV6 with gasoline...! help!
Page 2 of 3 <123>
Lateral5
Australia
Bobby wrote:
Vehicle incorrectly fueled and the ignition switch has not been turned to the 'on' position:
...not sure if there's anything recent.
Tell me....do they have a Tech note for.....
1) Wife fills diesel with petrol
2) Puts key in ignition and turns on
3) Turns key further to start engine
4) Drives car a few k's to shops
5) Rings husband and asked why car won't start?
6) Husband asked wife if she put petrol in car instead of diesel
7) Wife says no, then check receipt which says "Unleaded"
Cool Husband throws mobile phone across room and tells her to sort it out herself
It's now being towed to dealer for "assessment"
Rule 1 - Never ask your wife to fill your car, regardless of how many times you tell her it's a fu*@in' diesel and make sure you don't put petrol in it Banging Head RRS TDV6 Bluetooth, VR, Roof
Post #149019 Wed Dec 19 2007 9:01am
Shocked Shocked Shocked
Commiserations mate.... grounds for divorce I'd say Big Cry
Post #149022 Wed Dec 19 2007 9:17am
Lateral5
Australia
Thanks, definitely a quiet household tonight. RRS TDV6 Bluetooth, VR, Roof
Post #149033 Wed Dec 19 2007 10:09am
Bobby
Don't know if this will accelerate the divorce proceedings or we will have a noisy bedroom tonight... Rolling Eyes
Vehicle has run for less than two minutes:
1 . Referring to relevant section in the workshop manual, drain the fuel tank.
2 . Remove the fuel tank assembly.
3 . Remove pump/sender module and invert to drain excess fuel.
4 . Remove all traces of residual fuel within the tank using clean absorbent cloth/paper.
5 . Remove fuel filter and discard.
6 . Disconnect fuel supply to high-pressure pump.
7 . Flush all fuel lines (inc. fuel return) with clean diesel fuel and retain all fuel used.
8 . Check for magnetic particles in flushed fuel in any assembly removed.
9 . Remove both high pressure fuel rails and high pressure diverter rail taking care to collect any spilt fuel.
10 . Empty the fuel from the rails into a suitable clean container and check for any magnetic particles.
11 . If metal particles are present, continue from step 4.6 below.
12 . If no magnetic particles are detected, re-assemble the vehicle (with new parts as necessary - refer to GTR) and road test vehicle for at least ten miles checking for normal engine operation and no stored diagnostic trouble codes are logged.
13 . Return vehicle to customer.
Vehicle has been driven until it stops:
1 . Referring to the relevant section in the workshop manual, drain the fuel tank.
5 . Clean and flush all low pressure pipes.
6 . Renew the fuel filter.
7 . Renew the high pressure fuel pump.
8 . Renew all high pressure fuel pipes.
9 . Renew the diverter pipe and both fuel rails.
10 . Renew all six fuel injectors
11 . Reassemble pump/sender module to fuel tank and install to vehicle
12 . The tank must be filled with clean diesel fuel
13 . Road test vehicle for at least ten miles, checking for normal engine operation and no stored diagnostic trouble codes are logged.
14 . Return vehicle to customer.
Good luck! Malaysia Boleh!
4.2SC Chawton White, Stormers
Clear Side Repeaters, Towbar
Post #149034 Wed Dec 19 2007 10:31am
Lateral5
Australia
Thanks Bobby, mine falls in the latter category......I am just waiting on step 14 now Crying or Very sad RRS TDV6 Bluetooth, VR, Roof
Post #149037 Wed Dec 19 2007 10:51am
Lateral5
Australia
Actually, does "Vehicle has been driven until it stops" and "Driven until it no longer starts" fit in the same category? Rolling Eyes RRS TDV6 Bluetooth, VR, Roof
Post #149039 Wed Dec 19 2007 10:59am
Tim in Scotland
You will find out when you pay the bill! Hope that you have been a loving, caring and understanding hubby and didn't shout and scream at the good lady Whistle A Carbon Footprint is the mark a lump of coal makes when it's dropped on the ground.
Tata TDv8 HSE - Stornoway/ebony and straight grain walnut with towpack, Tasmods and an HST grille. Coming soon LEDs in the headlights
Staying - Epsom Green Defender 90 for playing off road
Post #149040 Wed Dec 19 2007 11:02am
Bobby
I would think so because the other category is "run for less than two minutes"!! Sad Malaysia Boleh!
Post #149046 Wed Dec 19 2007 11:47am
Lateral5
Australia
Around $9-10K is my understanding. Thankfully covered by insurance.
No, I was perfectly calm and collected........well sort of......well, no. Dropped in for a beer at the pub and that took the edge off. RRS TDV6 Bluetooth, VR, Roof
Post #149049 Wed Dec 19 2007 11:57am
Post #149051 Wed Dec 19 2007 12:01pm
Lateral5
Australia
.....Hope that you have been a loving, caring and understanding hubby and didn't shout and scream at the good lady Whistle
Her punishment has been dished out....especially now we are without motor
Post #149057 Wed Dec 19 2007 12:56pm
Tim in Scotland
And so much more environmentally friendly than using the RRS too Rolling with laughter A Carbon Footprint is the mark a lump of coal makes when it's dropped on the ground.
Post #149061 Wed Dec 19 2007 1:37pm
AXLEROD
Misfueling
Hi Tim
Sorry to hear of your misfueling experience. PM me to see how you can avoid doing it again.
Post #153572 Tue Jan 29 2008 5:05pm
Location: Growing old is mandatory; growing up is optional.
Tim's away with work wont be back for about 2 months and will probable miss this post by the time he's back
Maybe send him a PM??
Oh and welcome to www.rrsport.co.uk Thumbs Up RRS TDV6 Gone but still around
Shaguar Hard Type (know you all miss her but she's gone)
Oh and i love the girlzzzzzzzzzz!!!
Post #153583 Tue Jan 29 2008 6:22pm
Bobby
Re: Misfueling
AXLEROD wrote:
Hi Tim
Welcome, mate.
It wasn't Tim who had the misfueling experience.
Anyway, if you know a way to avoid doing it why not share the idea with the forum? Wink Malaysia Boleh!
Post #153591 Tue Jan 29 2008 7:14pm
Page 2 of 3 <123>
