Home > Technical > DVD troubles
berommen
Belgium 2006 Range Rover Sport Supercharged Zermatt Silver
DVD troubles
Hello, I have just bought a RR S/C 2006 with the rear seat entertaiment option.However when i try to load the dvd's I get the message 'video signal system is not correct'. Does anyone knows what I am doing wrong? Thank you. Sad
Post #148587 Sat Dec 15 2007 11:14pm
Know this is silly but you are loading them in to the mag in the boot right and not the dash? RRS TDV6 Gone but still around
Post #148592 Sun Dec 16 2007 12:08am
berommen
Yes , artwork facing up, evreything like it should be.Tied several different DVD's.
Post #148595 Sun Dec 16 2007 12:23am
Not sure sorry never seen that message myself!
Maybe a trip back to the stealers or just wait till the morning and see what one of the others have to say before you set off Thumbs Up RRS TDV6 Gone but still around
Post #148598 Sun Dec 16 2007 12:26am
Tim in Scotland
I wonder if one of the cables has been disturbed and might loose or unplugged - have you checked all the connections in the boot? 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #148617 Sun Dec 16 2007 10:48am
berommen
I'm not shure about that , they are not easy accesible. I guess I better take the car to my dealer to check that out. Thanks for the reply's. Thumbs Up
Post #148681 Sun Dec 16 2007 9:35pm
Thumbs Up Keep us updated please Mr. Green RRS TDV6 Gone but still around
Post #148690 Mon Dec 17 2007 12:07am
Bobby
Just a thought...
Are your DVDs correctly coded? The DVD Player fitted to your car will only play discs that are marked with the same region code as where your vehicle was bought. For example a European coded DVD player may not play DVDs coded for South East Asia! Malaysia Boleh!
4.2SC Chawton White, Stormers
Clear Side Repeaters, Towbar
Post #148692 Mon Dec 17 2007 12:31am
Makes sense Bobby Thumbs Up
Post #148715 Mon Dec 17 2007 10:59am
berommen
The car is a Belgian car and I tried 10 different dvd's with the european region code.I have my car back tomorrow evening, I hope they(dealer) found the solution. I will keep you informed.Thanks for the reply's. Thumbs Up
Post #148996 Tue Dec 18 2007 11:12pm
umbertob
United States 2006 Range Rover Sport 4.4 V8 HSE Chawton White
Probably too late, but this is from an old DVD troubleshooting bulletin.
Quote:
VIDEO SIGNAL IS INCORRECT
NOTE: If an incorrectly formatted DVD is installed in the DVD-C (for example a Region 2 PAL DVD disc used in a Region 2 NTSC DVD-C player) the message 'VIDEO SIGNAL SYSTEM IS NOT CORRECT' will be displayed on the front and rear LCD screens.
1. If the message 'VIDEO SIGNAL SYSTEM IS NOT CORRECT' appears, investigate the possible Root Cause:
• Selected DVD player video settings are the wrong format.
• DVD disk loaded is of a different format than the DVD.
• Corrupted or damaged (scratched or dirty) disk cannot be read.
2. If a cause is determined, make the appropriate corrections as follows:
• Check and replace any damaged disks.
NOTE: The remote control can select between the NTSC and PAL
video formats. The message should clear once the correct video
format has been selected.
• Press and hold the On/Off switch at the side of the remote control to
select the correct video format. (Figure 1)
• If the message remains, cycle the vehicle ignition.
• If required, disconnect and reconnect the vehicle battery.
Check to make sure you are not in the wrong video format using the remote (e.g. NTSC and trying to play PAL encoded discs) as per bold note above... It may be as simple as that. The On/Off button is the small one on the upper left side of the remote. Good luck, keep us posted!
Post #149018 Wed Dec 19 2007 8:18am
berommen
Hi. Today I got my car back from the dealer. They can't give an answer to the problem with the DVD player.So they contacted land rover and an expert will come to the dealer and will check out what is the problem. I will keep you posted but I have the impression that this will be a difficult one... Sad
Post #149264 Thu Dec 20 2007 11:53pm
umbertob
Rolling Eyes For Heaven's Sake, what more is there to "check out", I wonder? The DVD changer or RSE module don't work, put new ones in and get it over with! This "We're flying in an electronic warfare expert from London" crap sound like French for "We couldn't take a look at it but don't have the balls to tell you and hope you will go away now" to me, I've heard it before... Laughing Anyway, I assume you have tried the suggestions in the above bulletin on your own already? Can you imagine if you were able to make the thing work in your garage? They'd have to cancel the James Bond arrival!
Let us know how it ends, sorry to hear about your trouble.
Post #149266 Fri Dec 21 2007 12:02am
You do wonder... Rolling Eyes
Post #149284 Fri Dec 21 2007 11:25am
berommen
Problem solved
"• Press and hold the On/Off switch at the side of the remote control to
select the correct video format. (Figure 1) "
Today I decided to trie again what Umbertob send me in one of his replies and guess what , ... this time it worked.
I think i didn't hold the On/Off switch on the remote long enough the first time. I am leaving in a few days on a holiday with the wife and kids, so you can imagine the kids are happy that daddy (with the big help of Umbertob) fixed the rse system.
I still can't believe my dealer didn't managed to fix it. Anyway, thank you for all the reply's and especially Umbertob for helping solving the problem Bow down
Post #149568 Mon Dec 24 2007 12:03am
