Home > Technical > Low coolant level
Page 1 of 3 123>
Misery
Low coolant level
I'm sure there was a post about this, have done a searched and can't find anything. I had the message low coolant level come up on the dash, was wondering if there has been any faults that i should know about????
Bow down Bow down
Post #148565 Sat Dec 15 2007 4:24pm
View user's profile Send private message Send e-mail Reply with quote
Tim in Scotland
It's either a sensor fault or a cracked reservoir Mis, and a warranty repair which was covered by a technical bulletin.
Have you checked the level in the reservoir when it's cold and then run the car, get it well warmed up and then the pressure in the tank will increase - and if there is a leak there then it will show. Whatever it is, a visit to the dealer is on the cards........ A Carbon Footprint is the mark a lump of coal makes when it's dropped on the ground.
Tata TDv8 HSE - Stornoway/ebony and straight grain walnut with towpack, Tasmods and an HST grille. Coming soon LEDs in the headlights
Staying - Epsom Green Defender 90 for playing off road
Post #148568 Sat Dec 15 2007 4:40pm
Misery
Thanks Tim I thought as much, just a worry as it seems to be getting a little cold down here at the moment. Wink Wink Wink Wink
Post #148569 Sat Dec 15 2007 4:43pm
Tim in Scotland
I would also take off the oil filler cap and have a look in the underside to see if there is any foamy mixture - as yours is a petrol engine and if you are loosing coolant then your head gasket could be shot and the coolant is going into the luboil......................................££££££££££££££££££££££££££££££££££££££££'s A Carbon Footprint is the mark a lump of coal makes when it's dropped on the ground.
Post #148571 Sat Dec 15 2007 4:51pm
sportman
United Arab Emirates 2006 Range Rover Sport Supercharged Buckingham Blue
Re: Low coolant level
Bow down Bow down
that was my post, they change the sensor..it eas fualty 2007 Range Rover Sport Supercharged, Buckingham Blue, Ivory converted to HST Silver
V8 Defender 90 , 5 speed manual, lift kit, 1997 model
Post #148572 Sat Dec 15 2007 5:12pm
l
Spain 2006 Range Rover Sport TDV6 HSE Buckingham Blue
I had the same message this week Went to the dealers and they corrected the faulty sensor and installed a new container. RRS TDV6 HSE BUCKINGHAM BLUE BLACK LEATHER INTERIOR RHODIUM TASMOD SILLS CHROME GRILLE CHROME VENTS CHROME LETTERING PARROT 3000 EVOLUTION WHITE SIDE REPEATERS RRPORT.CO.UK BROLLY & STICKER
HOW GOOD IS THIS CAR!!!!
3 YEARS AND STILL GETTING LOOKS
Post #148573 Sat Dec 15 2007 5:32pm
Alicatt
Belgium 2008 Range Rover Sport TDV8 HSE Buckingham Blue
This fault is catching, I've just had one too and coolant level is ok, dealer here I come Sad Sons of dogs come eat flesh
Clan Cameron
Post #148576 Sat Dec 15 2007 6:27pm
Tim in Scotland
Don't all go into the dealers at once otherwise Land Rover will have run out and the parts will be on back order for weeks and weeks as they are not expecting a run on sensors and reservoirs! A Carbon Footprint is the mark a lump of coal makes when it's dropped on the ground.
Post #148577 Sat Dec 15 2007 6:54pm
Misery
Thanks Tim but I'm used to ££££££££££££££££££££££££££££££££££££££££££££ remember I have a petrol Big Cry Big Cry Big Cry Big Cry Big Cry Big Cry Big Cry Big Cry Big Cry Big Cry Big Cry Big Cry Big Cry Big Cry Big Cry Big Cry
Post #148584 Sat Dec 15 2007 8:05pm
Location: Growing old is mandatory; growing up is optional.
Well they'll have to not build so many new RRS then and sort out our one's first Exclamation Exclamation Exclamation RRS TDV6 Gone but still around
RRSport.co.uk Feb 2009 Meet
RRSport.co.uk After Meet Dinner
Post #148591 Sat Dec 15 2007 11:05pm
TB
United Kingdom 2006 Range Rover Sport TDV6 SE Arctic Frost
Rolling with laughter Rolling with laughter Rolling with laughter Rolling with laughter Arctic Frost TDV6 SE. Aspen Leather, Cherry Wood, Privacy Glass, PTI, Tow Pack, Mudflaps, Tasmods, a new Fuelflap, a RRSport.co.uk umbrella in the boot & a RRSport.co.uk sticker on the rear glass.
__________________
Post #148606 Sun Dec 16 2007 8:09am
Bobby
This was the original TSB...
TB# LS303-006
SECTION: 303-03
"Low Coolant Level" Message or Warning Lamp Illuminated
AFFECTED VEHICLE RANGE:
Range Rover Sport (LS) VIN: 6A900129 to 6A929342
CONDITION SUMMARY:
"LOW COOLANT LEVEL" MESSAGE OR WARNING LAMP ILLUMINATED
Situation: A customer may report that the "Low Coolant" amber warning lamp is illuminated or a "Low Coolant Level" message is displayed in the Message Center when the engine coolant expansion tank volume is within recommended levels.
The coolant level float in the expansion tank can absorb coolant causing the float to sink. The warning lamp and message will display when the float sinks below the low level sensor trigger point.
Action: Should a customer express a concern related to the above condition, within the specified VIN range, refer to the Repair Procedure detailed in this bulletin.
PARTS:
NOTE: The current expansion tank part PCF500015 may be used only if the sticker on the side of the part has a date of 31-10-05 (DD-MM-YY) or later. A newer part PCF500090 may be used when available.
PCF500015..............Coolant expansion tank (dated 31-10-05 or later) Qty 1
PCF500090..............Coolant expansion tank Qty 1 Malaysia Boleh!
4.2SC Chawton White, Stormers
Clear Side Repeaters, Towbar
Post #148687 Sun Dec 16 2007 10:59pm
Bobby Thumbs Up
TB it's not funny RRS TDV6 Gone but still around
Post #148688 Sun Dec 16 2007 11:04pm
Bobby
JayMann wrote:
TB it's not funny
Yes, I think that's a very serious and legit suggestion! Thumbs Up Malaysia Boleh!
Post #148691 Sun Dec 16 2007 11:12pm
TB
You all seem to forget that Ford Motor Company is on the verge of selling Land Rover and Jaguar to the highest bidder. At the moment they are trying to wringe every last penny out of these companies to maximise their profit margin. Do you honestly think that they would even think about stopping production on their best selling (profit making) model because a couple of customers have got "Low Coolant" messages.
Simple economics: The production line stops for a couple of minutes - That's one RRS that doesn't roll off the production line. Cost to the company - £40 - £50K.
Cost of a new coolant bottle is probably less then a tenner.
If it was your company what would you do? Stop the main production line for one hour, losing over between one and 1 and a half million pounds. Or tell a couple of unhappy customers (who have already paid for their vehicles) "Sorry, you will have to wait a while because we don't have any parts in stock".
I'm sure you will agree, this is a no brainer. Arctic Frost TDV6 SE. Aspen Leather, Cherry Wood, Privacy Glass, PTI, Tow Pack, Mudflaps, Tasmods, a new Fuelflap, a RRSport.co.uk umbrella in the boot & a RRSport.co.uk sticker on the rear glass.
__________________
Post #148700 Mon Dec 17 2007 7:50am
Page 1 of 3 123>
Copyright © 2005-2009 Martin Lewis
