| Home · FAQ · New Posts · Private Messages · Search · Members · Members Map · Calendar · Profile · Donate · Register · Log In |
![]() | Home > Technical > Filled up my TDV6 with gasoline...! help! |
| Tay_pt Joined: 16 Mar 2007 Location: Porto Posts: 55
Well... Wednesday was one of those days I shouldn't got out of bed.
| MAW Joined: 06 May 2006 Location: Lincs Posts: 710
I'd have thought it could be pumped out easily enough |
Me also, but apparently there’s some kind of device inside the tank feed tube that prevents a burglar from pumping out gas. This is a clever idea… as long you design some other way of purging the fuel out, besides taking out the whole tank! |
Thanks RAD,
| shmoogle Site Moderator Joined: 07 Sep 2005 Location: My arse, Your face. Posts: 19964
Bad luck Tay_Pt - this can happen to the best of us. At least you didn't start the engine - so you face the least amount of work/money to get it sorted. I'm not sure of the RRS, but I know of a friend's Freelander 1 that this happened to (although he did run the engine before realising what he'd done) and that cost him a LOT of money to rectify. |
| Tim in Scotland Joined: 30 May 2005 Location: Driving along in my automobile Posts: 7398
Cost is usually a new fuel system and engine because LR reckons that the benzine in the gas ruins the seals in the common rail diesel system, which operates at some hugely high pressure so they start you from scratch with new mechanicals and fuel system. A Carbon Footprint is the mark a lump of coal makes when it's dropped on the ground.
| Bobby Joined: 07 Jun 2005 Location: Kuala Lumpur Posts: 1812
This is on the Service Bulletin that was issued on 13 June 2006..
Note that it isn't a case of starting the engine, it says above "turned to the ON position" That is position 1 in the sart procedure, as the high pressure fuel pump starts then in anticipation of the driver starting up. A Carbon Footprint is the mark a lump of coal makes when it's dropped on the ground.
Okay. If he has turned the key BUT did not start the vehicle...
Well thank very much guys for all the info. It was exactly this I was searching for.
| Endjin Joined: 22 Jun 2007 Location: Aberdeenshire Posts: 481
Glad to hear you got it sorted Tay_pt |
300 Euro is a lot better than 10x that if you needed a new engine etc... good outcome |
| Very Annoyed Site Moderator Joined: 23 Aug 2005 Location: bat-wielding monkey-spanking tough-love zero-tolerance Euro-sceptic moderator - So just watch it! Posts: 14695
Good result TBH - could have been a lot worse. RRS 2.7 TDV6 HSE Zambezi silver,Alpaca.
Staying - Epsom Green Defender 90 for playing off road
