| Home · FAQ · New Posts · Private Messages · Search · Members · Members Map · Calendar · Profile · Donate · Register · Log In |
![]() | Home > General > windscreen wash levels |
| Biggles Joined: 26 May 2005 Location: Preston, Posts: 916
Scorpio,
| Bobby Joined: 07 Jun 2005 Location: Kuala Lumpur Posts: 1904
| caporajm Joined: 25 Jul 2005 Location: Austin, MN Posts: 55
I think (I could be wrong) that scorpio doesn't know how to check the windscreen wash level. Forgive me if I am wrong b/c I don't want to insult your intelligance, but I think that's what they're trying to understand RRS S/C Special Edition, Vesuvius |
Scorpio
| scorpio Joined: 08 Jul 2005 Location: London Posts: 142
thank you all for your advice, i think i can manage to fill it up, but even years ago i had a humble honda, and that had a dip stick device to check the level, |
| RRUK Joined: 10 Jun 2005 Location: Certainly In-Vogue Posts: 2239
Long gone are the days of the Range Rover Classic where you had a huge 2 gallon clear plastic reservoir sitting in the top of the engine bay for all to see, no, most modern cars have the bottle tucked up inside a body panel and just a filler neck to see from the engine bay. My M5 is like this and so when filling up I listen for the different sound it makes as it's getting fuller, and then stop as it reaches the mesh filter in the filler neck.
| Simon Joined: 13 Jun 2005 Posts: 44
the oil light should tell me when the oil is low, i did not spend £40,000 so that i could lift the bonnet every week to check the levels etc, nearly all cars today have levels that are indicated on the dashboard,
| Smarticus Joined: 26 May 2005 Location: Northumberland Posts: 670
Bobby
| MDP Joined: 15 Jun 2005 Location: Back in an AUDI Posts: 8598
My Audi S4 cab has a diagramatic pic ( animated ) of low water level in the screen wash resivoir which holds water for screen/headlamp wash. |
| keith Joined: 04 Aug 2005 Location: Scotland Posts: 43
Does the RRS have a second washer bottle for concentrated washer?
