Home > Technical > Transmission Fault - Traction Reduced!
trap2
When I switch on my RR Sport I get this message. It doesnt happen every time - maybe one in five times.
I phoned my dealer and they said its nothing to worry about (!). I'm not convinced!!
Anyone else had this problem?
Post #12068 Thu Feb 02 2006 7:30pm
LRtuning
2006 Range Rover Sport Supercharged Cairns Blue
It's a wiring loom problem...book it in to the dealer? Chips with everything
Post #12069 Thu Feb 02 2006 7:31pm
avus
United States 2006 Range Rover Sport Supercharged Chawton White
specifically, what type of wiring loom problem? is it incorrectly installed, or does it need to be changed completely?
235 miles on my rrs s/c and this message has showed up. i just turned it off, and restarted the LR -- message did not reappear.
Post #12548 Wed Feb 08 2006 8:42am
grommet
United States
Sorry, there is no "simple answer" to a fault like that... it could be many things. I know two people that have seen this error a few times in perfectly boring weather, but it clears after restart. One RRS S/C and one LR3. And there is nothing logged in the computer afterwards... shades of "bug." If it impacts the actual drive, then I'd be worried.
Post #12593 Wed Feb 08 2006 10:01pm
LRtuning
Have the dealer check the wiring loom on rear of gearbox Chips with everything
Post #12596 Wed Feb 08 2006 10:33pm
tglick
United States 2006 Range Rover Sport Supercharged Java Black
Transmisson Fault...
I have the same problem. However, it occurs everytime I drive the car - usually right after start up, but once in a while it occurs 5 or 10 minutes after. When it first started occuring, it didn't happen everytime I drive, but more like every 5 times I drive. I brought it to my dealership and they couldn't get the problem to reoccur. Ironically, as soon as I pulled away from the dealership it occured again. They said that there is no way to find out what the fault exactly means without hooking the computor up to the vehicle while the fault is present - this is the only way to trace the code that the fault is sending out. They checked the car out from top to bottom and said mechanically there is nothing wrong and it is ok to drive. As soon as I have a free weekend, I am bringing the car back in with the fault on the screen to get to the bottom of this. If anyone else finds out the source of this problem sooner, let me know.
Black/Black Supercharge
Post #12790 Fri Feb 10 2006 7:14pm
