| Home · FAQ · New Posts · Private Messages · Search · Members · Members Map · Calendar · Profile · Donate · Register · Log In |
![]() | Home > My Range Rover Sport > Biggles - 2.7 TDV6 |
| Biggles Joined: 26 May 2005 Location: Preston, Posts: 916
Have bought,
| nickp Joined: 27 May 2005 Location: Leicestershire Posts: 111
Hi Biggles
Not seen any of these suspension messages, but have seen today the red handbrake light staying on after removing the ignition key for about twenty seconds.
I also get the handbrake light which seems to be normal and the low power mode is designed so the volume wont go so high I think when the car is not running. If you get a chance play around with the suspension from access to off road a couple of times and see if you get the warnings. |
Nick,
Biggles
| NeilR Joined: 21 Jun 2005 Location: wakefield/West Yorkshire Posts: 146
Hi
Hi NeilR
| grommet Joined: 28 May 2005 Location: Northern California Posts: 299
"Suspension raising slowly" is not a fault exactly. It just means the air tank doesn't have enough saved and the air compressor is used to assist. Many people don't even notice... (same on Disco 3/LR3) |
New Accessories Fitted,
My first pic posted ( she has just been washed after a week getting dirty)
| BN Joined: 10 Jul 2005 Location: Northamptonshire Posts: 58
Biggles, take a look at the string I started http://www.disco3.co.uk/forum/viewtopic.php?t=798
Have just added the supercharged grille side vents and also the front and rear black Landrover badges.
| RRUK Joined: 10 Jun 2005 Location: Certainly In-Vogue Posts: 2225
BIggles, how easy are the mud flaps to fit? They look simple from the instructons online, is that the case? |
